Hi all,
I have loaded the pixologic alpha collection which is large collection.
But when working on a project sometimes you use certain alpha’s. The problem
is i need to go (scroll thru all the alpha’s) (spotlight) Which is long process. To finally
get to the alpha you might want.
Would It be wise to make smaller folders (sets) which has certain alpha’s?
-stone
-wood
-skin
and not have one large set.
secondly can you TAG alpha’s. like example. You are working on a piece, but then
you might use certain alpha’s.
if you restart zbrush.
and work on second piece, you need to know which alpha’s you used for the first piece.
they arent in the pallete any more.
How would I get the alpha back you used on the first piece.
Now I’m writting them down. So i know which one I used.
I’m just wondering if there’s a other way. To do this.
Thanks in advanced
