re frame model
hi
not a major problem, more of a pain in the backside, every time I minimze zbrush or jump to another application, then go back to zbrush my model disappears out of frame and I have to click the frame button, using zbrush 4r5, any ideas why?
thanks in advance
doesn’t happen to me, but F is the frame key, btw.
This probably wont be the case if it happens every single time you switch tabs (especially if its only for a second or two), but 4R5’s autosave feature can give the appearance that the model has disappeared until you basically do anything to refresh the document
not sure why its happening, started with this update, not a major problem just a pain, cheers for the shortcut, never really use them, but ‘f’ may become a favourite :slight_smile:
Ah, that would be it, thanks matey!
