My first post, hi everyone.
I have invested in 3.1 and am following an exellent digital tiutors disc. At one point I am told to enter RAPID UI to access brushes. I understand that RAPID UI is dropped from 3.1. Do any wise members know what mode I must now choose? Has RAPID UI been replaced with something else?
I basically want to finish the tut.
Peace
use the brush palette on the left hand side…
Thanks for the reply. Ok I will go ahead and use the sculpting tools without entering any special mode.
Thanks
Peace.
The Rapid UI was retired as a short-lived experiment. Most of your tools should be pickable from the left. I believe that Pix found the RapidUI was discouraging users from learning the full UI and thus creating more problems than it solved. In most cases the buttons and features mentioned in the tuts for Rapid UI can be found in the logical counterparts in the “standard” UI. Just be prepared to have more choices than before.
HTH,
-K
I think I am following the same tutorial and am wondering if there is still a “Tweak” brush or has it been replaced also? If so, is there a similar brush? Thanx for any help.
It’ called the “Move” brush now. Ideal for pulling points around in screen space.
-K
