Randomize Micromesh??
Hey guys is there a way to randomize the objects on a micromeshed surface?
thanks!
-Lee
Not the objects. But you can use various methods to break the model into different polygroups which can then be split off into their own subtools. From there you can use micromesh to assign an object to each subtool, with the effect being randomization across the surface.
