Hello I’m not sure if these are bugs or not pixologic makes things different then everyone els regardless if its good or bad, So I’m not sure if I just do it wrong or not.
So if anyone can help with any of the questions below, I would appreciate it.
If I have my object zoomed in, so it covers the entire workspace, and tries to move, rotate and scale, by pressing outside the frame. 50% of the time the objects disappears from the screen and I have to repeat the action, and then it works. I don’t have to recenter the object I just press outside the frame again and the object then appears at the same position scale etc as before. Why didn’t it work the first time? (I have a wacom tablet)
Another strange thing I discovered is that I have to change subtool before my hotkeys starts to work, and ctrl+Z only works on random occasions, hardly at all. Does anyone know of a hack or secret key combination to make it work?
Clone Tool for pollypaint, how do I do that? As far as I can tell the clone tool in Spotlightonly works on texture maps, am I wrong?
My current solution is to GoZ to Modo, but its no fun when the file takes 10 min to save.
If I have a texture in Spotight/Lightbox and I want to paint the texture in its original scale, how do I do that?
Does anyone know how to get a warning from zbrush when I save a file that is to large for Zbrush to open?. I don’t want to check in the folder every time I save, if it is 2 gb or 4 gb.
