Radial symmetry question
Can I sculpt using radial symmetry along a pipe that’s curved? Or does radial symmetry only work in XYZ axis?
i can’t find the answer for this anywhere. Thanks
No, the radial symmetry will only work relative to a fixed axis.
So how would I go about this? Any way? I have a twisting pipe that I need to draw radial symmetry down the whole length of it.
Only thing i can think of is doing it all when the pipe is straight and then bending it in the end?
Well, that would be one way of doing it. But what sort of detail are you going to sculpt? If it’s repetitive you might be able to make a Tri Parts Insert Multi Mesh brush so you could create the pipe and detail all at once.
