Hi guys,
I switched up my Wacom settings to make working with ZBrush easier (I’m trying to avoid touching the keyboard) and I ran into a problem.
It seems that in the radial menu for the Wacom tablet it doesn’t detect Control + D. I can see it in the window when I go to customize it but the actual command doesn’t work within ZBrush.
Is this a Wacom bug or does it do this for anyone else?
I guess I’m asking if you guys have a radial menu setup are there any modifier keys in the command such as control, shift, option, etc?
