R8 Transpose Inflate not working
I have an issue with the Transpose-Inflate feature in R8. When I Right-click on the last red circle of the T-Line/Move to inflate, the canvas rotate instead of inflate. I tried to deactivate “R-Click Navigation” to spot a eventual conflict but i doesn’t work either. “Enable Transpose Inflate” is activated in the Preference menu too.
The feature works great in R7 and before, even with “R-Click Navigation” enabled.
Confirmed here as well. Right click transpose functions appear to be broken in R8.
You can inflate with the new Gizmo, however, by ctrl-draging the inner scale control.
If you haven’t done so already Nik, please post this in the 4r8 part of the forum: http://www.zbrushcentral.com/showthread.php?207226-Questions-amp-Troubleshooting-for-ZBrush-4R8
Thanks for your awnsers,
Spyndel just add the issue to the thread, I hope it will be fixed i’m used to it :slight_smile: Btw thanks for the Gizmo trick!
