R3 crashing when using masking with transpose.
As the title says, when im using the masking method that gets used for transpose, Zbrush instantly crashes. This also happends with Subtool master and only certail models.
Now I cant post the model in question, but hoping that there is a workaround or soloution to this problem.
This is happening to two computer with with Win 7 home 64, the other with Vista 32.
Here is the techinical info.
Problem signature:
Problem Event Name: APPCRASH
Application Name: ZBrush.exe
Application Version: 3.5.3.0
Application Timestamp: 4b0bfb06
Fault Module Name: ZBrush.exe
Fault Module Version: 3.5.3.0
Fault Module Timestamp: 4b0bfb06
Exception Code: c0000094
Exception Offset: 0111dff9
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 2057
Additional Information 1: 462f
Additional Information 2: 462f57ec7ef6584ad05b37264e37f769
Additional Information 3: f0d6
Additional Information 4: f0d68275a997e7dbc801694b781bcb40
same problem for me, I use this a lot in my work flow and it is really stopping me in my tracks sometimes.Has anyone found an answer?
I am searching all of the masking threads for this problem and another that I don’t see posted yet. I will start another thread for that one.
Sounds like your model may be subtly corrupt.
i’ve had this happen quite a bit, only certain models, i’ve seen other threads about it too, anyway for me it only happened when part of my model was hidden, or rarely had a subtool with inverted normals.
