So with 3.5.3
If I start a new Quicksketch doc do some drawing then switch to a tool, the tool is flat shaded (as to be expected since Quicksketch uses the flat shader by default).
However, changing the tool’s shader to anything else such as (chrome A, matcap red wax, etc.) the tool looks very dark as if the lighting never gets updated or switched back to the default lighting scheme for tools.
Resetting using Default Zscript does not fix this.
Resetting using new document does not fix this.
Restarting Zbrush was the only way to resolve this.
Can anyone else confirm this?
