Quick Pick tray
Hello,
When I click on the large tool thumbnail (in the tool menu) the tray expands out. On the top is a ‘Quick Pick’ row. Is there a way I can put my own meshes in this row? I often use a cube with six sides (no radial points) and it would be great to see it in the expanding tray. Specifically in the quick pick row.
Thanks
The Quick Pick tray is simply the last used items. It’s not possible to have something permanently in there. It can be cleared by pressing the ‘R’ button at the top of the palette and will change if you load a new project.
The simplest way to have your favorite items available is to load a project with them in. You could set this up exactly how you want and then load as needed. It would be possible to have a macro load this project so all you need do is press a hotkey.
