Quetion: Is it possible to run ZBrush+zscript from command line?
Hello there
I’m finding way how to launch Zbrush and then in same time launch zscript.
So it should be some .bat file that:
  1. Launch Zbrush and waiting while it will be loaded
  2. Press button with my script
About launching Zbrush i find information but how to run script automatically after launching zbrush i did not have answer.
Regards
You need to use a zscript that runs automatically without any button presses. So, for example, you can enclose the code you want to run inside an [If…] statement that always evaluates to true:
If,1,
Note,“Hello world!”]
Then all you need to do at the command line is enter the path to ZBrush followed by the path to the zscript (either *.txt or *.zsc):
[FONT=Courier New]“C:\Program Files\Pixologic\ZBrush 2019\ZBrush.exe” “C:\Program Files\Pixologic\ZBrush 2019\ZScripts\Hello.txt”
This works for me if the path is on C: or D: drive, but how to use UNC paths? For example I want to start script that is located on
\\my-network-share\my_scripts\script_001.txt
“C:\Program Files\Pixologic\ZBrush 2019\ZBrush.exe” “\\my-network-share\my_scripts\script_001.txt”
does not work
