Questions on subtools and appending.
For my model I created a subtool from the main piece and unified all of the polys so I could use an insermesh brush I created (to make claws and spines). However, when I cloned the spines into their own subtool and then tried to append them onto the base model (which was the same as the cloned one) they did what you can see. How can I fix this?
When you used Unify is when stuff went wrong, you did all the subtools? http://docs.pixologic.com/user-guide/3d-modeling/sculpting/sculpting-brushes/insert-mesh/creating-imms/
You can use transpose and move or under geometry is position, or deformation panel. Be sure to deselect any axis you don’t want to alter.
