Hi I use Wacom intuos 4 with zbrush 4 on XP 64bit.
Here is an example scenario:
I am at a higher subdivision level and say i pressed the button to render normal map, It will not happen because i am not in the right subd level, right… a tiny pop up massage will inform me and Offcourse i will correct my mistake and will move on. But… in my case that pop up massage or ANY pop up massage for that matter, disables my Pen and If I click somewhere on my screen to get rid of that pop up(thats what I am supposed to do) It doesnt work. UNLESS I use my mouse which stays Idle for the most part otherwise. Then i click somewhere on screen in ZB with my mouse and everything goes back to normal. pen/tablet works perfectly fine untill the next pop up when I will use my mouse… I think its a bug or may be something is wrong with my settings.
Has anybody else experienced it?
any solution?
many Thanks in advance.
Cheers
Except reinstalling your driver, I have no real idea as I never heard/had this problem.
If you are running on Windows 7, I strongly advise you to disable the system tablet PC services if you are not using it.
thank a lot totyo for your response.
I mentioned my OS as XP64 bit not win 7.
But good suggestion because I also use it on my small netbook (Toshiba N300) sometimes which has win 7 starter edition. I will check if the same thing happens on that.
but thanks anyway.
cheers:)
