Question: Using A Insert Curve Brush...
When using a insert curve brush is there a way to make the starting point and/or end point face the surface so as to make it easier to plug/insert into an object?
Also is there a way to freeze a part of the curve so I can continue to adjust the curve without interrupting the parts I like?
The curve will align itself in the direction of the object’s normals (the green lines at each end show you the direction). You will have to start/end the curve on a mesh portion that is flat to the screen plane.
You can turn on Lock Start and/or Lock End in the Stroke palette Curve section but I don’t think there is a way to ‘freeze’ part of a curve. You can stop the whole curve changing shape by turning off Stroke>Curve>Bend.
Okay thanks!
