Hello.
I do not write English well.
Zplug SubPalette start click!
Tutorial View opening Zscript?
[IPress,TUTORIAL VIEW]
[attach=60373]Tutorial_View_Open.jpg[/attach]
Hello.
To automatically set script window size, you should
GO TO THIS PAGE and CUT AND PASTE script #4. from there and put into your own script.
What: Adjusts the height of the Zscript Window to fit the active Zscripts interface.
Why: Assists user workflow when switching between Zscripts that utilise the Zscript Window.
When: Performed in Zscripts that display in the Zscript Window.
Descripton:
Zscripts that display in the Zscript Window have varying interface sizes. Switching between such zscripts usualy requires the user to either increase the height of the zscript Window to view its entire interface or to decrease the height so as to not waste valuable screen space. Automatic adjustment of the Zscript Window’s height would help workflow.
You should not worry about implementing this functionality while writing your zscript. You can and should wait until your Zscript Window Interface is finished before thinking of adjusting the ZW height.
[attach=60383]script window height.jpg[/attach]
Oh! Thank you Svengali.
