Question: Repeated Geometry
I’m trying to replicate a piece of geometry over and over and at the same time scale it smaller. Kind of like a vertebrae (spine). If there’s a tutorial out there on this, can someone point me in the right direction?
Thanks!
I’m no expert, newbie myself so there may be a better way, but if you use the move (transpose) tool, use ctrl and shift whilst moving this will duplicate the geometry, then you can scale it a bit, then repeat the process. That way you can create several slightly different / scaled version of the same geometry. Not automatic I realise.
Hope that helps a bit.
Steve
