OK. Here’s something I have been trying to figure out, but am about ready to give up on.
The FileNameAsk command permits the script to ask the user for a filename, either something to be saved or loaded, and it does it in the typical dialog window which shows the files that already exist. You either select one of the existing files or enter a new filename.
Swell, very useful. It works great…
Problem is, I can’t see anyway the FileNameAsk command can be pointed along a specific subdirectory path. Depending on the context, it selects the subdirectory that the ZScript is in, or the ZScript2 directory.
I would really like to create an exclusive subdirectory where the script will save and load data… and point FileNameAsk command to it.
Has anybody uncovered the technique to be used here?
Sven
. In this case, I am probably a little out of my league, as well.
. Maybe there are some Windoz/Zscript programmers who might throw in a suggestion or two (he said, hopefully.)
