Modeling rendering and animating are rather strong. So you can create rather large scenes. I was playing with it and as it happened I ended up having 6Mio Poly’s inthe scene. THAT is a lot. Max blows up with that amount but I don;t knwo what Maya does… Translate that into architectural dimensions and you have literally thousands of houses in the scene or hundreds of creatures… If you have the middle package then you also have the compositing app enabled and then rendering different passes to create those really stunning image results is as simple as 1 2 3. Define those pathes, plop them together in a tree like fashion, press a button and all is rendered and put together into the final image. You can tweak the compositinig tree in a gazillion ways while adding lens flare (or not 8-)) and glow and motion blur etc. etc… And of course… all is animatable and motion picture based. Quite a lot of stuff you get. Already with the entry package!.
And riging a character is as easy as importing your ZBrush Character, drawing a sceleton into it (pretty much like the ZBrush 2.5 demo shows with ZSpheres) and then press a ‘Envelope’ button and tatdaaaaa instant bendy creature. When the seams don;t fit. Open a weight paint window and smooth the influence between the bones simply with a brush.
And if you press an ‘auto’ button while bending your creature… you got your frist animation.
AND allthe operations STAY alive in a non linear operator stack. So you can go back to the first modifications of your character even when he’s all rigged up. You do not have to delete animatins and everything just to make the nose bigger. OR even add another nose…
TO master all the functions will take some time. But I started only using the modeling bit and then slowly gyrated into the other realms. That was supported nicely due to the fact that there are buttons you press for ‘Modeling’ or ‘Rendering’ or ‘Animation’ or’Simulation’ etc… which change the desktop slightly to optimize access to the special funtions unique to the task at hand. So when I am in modeling mode no rendering specific stuff is cluttering my workspace. However, I can still reach all that through sub menues OR simply pressing the Render mode button. Buttons are 1-5.
Give it a try when you can afford a couple of hours. It’s neat.
Lemo
Me,
