Considering this pict, when I start ZBrush I’ve always get the Config 1.
Whatever I do, saving the config after modifying it like Config 2, when I restart ZBrush, kaboom !, back to config 1 !. What can I do to get rid of this one ?
A config file stores the position of the interface elements. However, with few exceptions the particular settings of those elements is not saved.
The easiest would be to either modify your startup ZScript to activate the particular settings that you want at launch, or to record a macro that you can then manually run after launching ZBrush which will turn those settings on. You can even assign a hotkey to that macro if you’d like.
Thank you aurick
But how to modify the script ?
The startup ZScript is full of hieroglyphes …
