I fired up zbrush today and can’t figure out what happened to the subpalettes under the tool palette. I tried looking to see if there’s a spot to toggle it back on but can’t find it anywhere. I talking about the deformation, geometry etc under Tool on the right side. Only the load tool, save as and the brushes are showing. I tried searching the docs, google and search threads here, but nothing. Anyone know where to turn the subpalettes back on?
Do you have a 3D object selected? The palettes change their offerings depending on your current selection. If a feature can’t be used with your current tool, it won’t even appear in the interface. So if you have the Simple Brush or another 2.5D brush selected at launch you won’t see everything else in the Tool palette.
