hi can anyone help me im a noob at this tho iv spent the last few weeks learning it zbrush that is having worked out 3d sculpting and changing division levels for texturing etc I’m finding difficulties with creating texture maps with projection master. it seems to work the first time make something from scratch then never again if i load the tool i made the purpose of this is to generate a seperate texture map to load into second life to suit the sculpted shape from z brush. grr it seems to work sporatically
help! anyone
Well, it usually helps if you show the issue that you’re having. A picture is worth a thousand words.
But I recommend that you begin your texturing ventures using PolyPaint. See the online documentation in my signature.
