Hi guys,
First off, let me say I did look at the ZBrush manual, but I’ve had some strange issues and just want to make sure I am understanding saving ZTools correctly.
I have three questions:
What is the difference between saving a subtool with the “Save As” button in the tool palette vs saving a subtool using Subtool Master?
If I save the top level subtool using the Tool menu’s “Save As” command that saves the tool and all of its subtools correct?
If I want to save only a subtool and no other part of a subtool or a base mesh is there a way to do it?
Is there a special way to save a ZTool with all of the texture or polypaint information attached? The reason I ask this is because before I’d save a ZTool (using the ZTool palette’s Save As", and the materials assigned to it are gone when I’d load them back up. Well, this time I loaded a ZTool of the snowman I posted earlier and all subtools, materials, and colors loaded too! (This was in a new document not in a saved document). I was happy about it but according to the manual (unless I misunderstood) thatonly the mesh, not the materials should have loaded.
Sorry for all the questions but it’ll help clear up a lot of confusion for me with saving. I also promise once I learn this program well to help others
