Question about Smart Resym please help!
I’ve used Smart Resym on my (first) model alot, but now when i try to do it it says: Symmetry result: 0.00179% Symmetry points found. Symmetry map was not stored.
So that obviously means that it can’t be Smart resymt for some reason, but what reason??
I can’t go to a lower subdivision level I think because I saved the tool in a high level or something…
PLEASE HELP ME OUT!
You could try to get those subdivision levels back by using Tool>Geometry>Reconstruct Subdiv
Another thing you could try would be to use ReSym before Smart ReSym. Sometimes this works.
Thanks for your Reply Aurick,
but unfortunatly the problem is still not solved…
When I push the reconstruct subdiv button nothing happens…at all,
and when I push the ‘resym’ button, the exact same thing happens as when I pushed the SMART resym button…
Super late reply but I had the same problem. Just make sure UVs are enabled under texture menu and the mesh cannot contain triangles. Hope that helps.
yeah pretty late reply,
By now I’ve build a career, divorced three times and have 4 kids…naw just kidding:P
I’m not ‘struggling’ with the problem anymore, but you just gave me a little more insight in this so thanks for that!!
Slice
