Hi All, I have today a post from Keyshot offering 20% Off, What i don’t know is do I need the bridge and keyshot or just one of these. Thanks
H.D
H.D
Hi rachel,
You need to have the ZBrush to KeyShot Bridge for any version of KeyShot to work with ZBrush. This will cost you $149. But if you don’t need direct import into KeyShot then the cheapest way is to buy one of the KeyShot for ZBrush versions:
You can see them in the Pixologic store here:
http://store.pixologic.com/Single-User-License/
So the cheapest route to using KeyShot and ZBrush together is $349.
HTH,
Hi Marcus, thanks for the info, so to understand, I NEED ! keyshot 6 HD for ZB + bridge at minimum ?
Correct I don’t need direct import.
H.D
Yes, that’s right.
