Quad or Triangular polygons?
Does Zbrush use quad or triangulated polygons?
Thanks
Patrick
'Evening Patrick Martin, welcome to ZBCentral . . . :slight_smile:
ZBrush’s native polygons are “Quad”, but it can load “Triangulated” polygons & convert them to Quad. ZBrush can also convert it’s native Quad polygons to Triangular for exporting. :wink:
Have a good one . . . :cool: Mark.
Good evening Patrick and Welcome to ZBC!
ZBrush generated objects are quad based but ZBrush can import and export both quads and triangles (ZBrush prefers quads).
When importing an OBJ/DXF file composed of triangles you can instruct ZBrush to leave the mesh ‘as-is’ or convert adjacent triangles to quad by increasing the value in the TOOL :small_orange_diamond:INVENTORY :small_orange_diamond:TRI2QUAD before importing.
When exporting a mesh, you can instruct ZBrush to export the mesh ‘as-is’ (usually quads) or to convert quad to triangles when exporting by selecting the TOOL :small_orange_diamond:INVENTORY :small_orange_diamond:TRI option.
This info is also explained in the TextureMaster ZScript which I highly recommend that you download (if you haven’t already).
Hope this helps…
jaime
Edit: I see that Kruzr has already answered this while I was typing :slight_smile:
