QRemsher error
Hi.
I just tried out qRemesher on dynamesh I made in about 2 mins, qremeshed it just fine, fiddled around with polycount slider, tried it out a bit. Works fine, even on higher poly .
Then I load up a sculpture I have about 399K polys, zDecimated (all triangles ) , so I taught I might wanna retopo with qremesher.
I set up my polycount slider to approx. 1/4 of the original polycount, start qremesher.
It stasts cleaning up the mesh, everything goes good, when progress slider is about 1/3 however, it stops and gives me ‘Remeshing error encountered. Remesh cancelled’
I have tried the same with two other zDecimated models, same thing. That’s basically what I need to do, qremesh my old zdecimated models into quads. Is it so that it’s not even possible to qremesh zdecimated triangles at all ?
Any help appreciated.
try to dynamesh your model, and then qremesh it. it schould work.
it wud smoothen all details out
choose a high resolution and use the “projekt” button too, try it, it wil keep the details;)
