QRemesher
Working on a model that was several million polys. Trying to retopo it using QRemesher but I get a message saying that the sculpt consists of various subdivision levels and then the operation cancels? (when trying to freeze the subd levels) What am I missing and how do I ensure all subd’s are even so I can use the freeze subd levels button successfully to transfer my high detail over later?
Duplicate the tool (model) and then go to the sub-division level you want to start from (lower or higher) and delete the higher and lower subdivisions. From there run your retopology, Qremesher, and then reproject the details from the original tool (model). Even if you do it the other way with freeze subdivisions it can be good practice to work on a duplicate in case something goes wrong.
Thank you for the help.
