qremesher issue - (answered )
so at work, we’re running win xp 64bit version which is kind of an odd duck operating system and not that popular… but the previous iterations of zb has run fine and 4r4 works great too… with the exception of qremesher.
the error message when i hit the qremesh button:
qremesh.exe - Unable To Locate Component
This application has failed to start because MSVCP100.dll was not found. Re-installing the application may fix this problem.
OK
can i manually copy that dll? and where do i copy it into? i’ve installed that MS package when zb4r4 asked me to do it and i even rebooted but that dll is still MIA.
thanks.
jin
nevermind.
just downloaded http://www.microsoft.com/en-us/download/details.aspx?id=5555 and installed it and it worked without having to reboot even…
it may have been that the zb installer tried to install the 64bit vc+++ package but for some reason, a lot of 64bit stuff doesn’t work on winxp64 … :stuck_out_tongue:
so installed the x86 version and everything is peachy.
thanks.
jin
