Q remesher brings in a totally different job?
I’m using q remesher on an image of a praying man. when I use the q remesher it takes a while and then when it is done it brings in a totally different job of a panther? What is going on? Tried several times and restarted.
Got screen grabs? You using latest version ZB4R4 P2?
I’m using 4r4 p2 on a mac. Have recreated it several times. tried restarting. Renaming file. Decimating figure first and then trying qremesher. same problem. I have had it work before, but something is acting buggy. This is an imported file, but I have done it before with imported files with no problem. any help would be greatly appreciated. I’m under deadline and can’t sculpt on this mesh.
Try optimize points order before Qremesher, automask on, set to same number of points. Might be worth a shot. Are you importing an .obj?
What version of Mac OSX are you using? QRemesher is only compatible with OSX 10.6 and above.
