Proplems with TransposeMaster
I just working on a new Illustration , and for that I want to pose my characters …
I have a Model with Subtools and want to use TposeMaster and a ZsphereRig …
so i hit TPose Mesh - (ZSphere Rig) (Grps) and get my modell and the Zsphere … so i do the rig and bind the mesh.
After I´m satisfied and finsihed I went back and hit TPose-SubT … I get a Error … with no matching Data … I don´t know what I´m doing wrong ?? Is it maybe I have Grps on or my Layer in the Subtools …
Does anyone know this issue with TPoseMaster and other traps I dont know ??
Thanks a lot
Do you get the same error if you use Transpose Master without using the ZSphere Rig option? Try it without posing the mesh at all, just sending straight back using the TPose>SubT button.
Hey Marcus … I can do what ever I want I just tryed it out with the Demo Soldier … and did nothing … and no pose
just back with Tpose>SubT I get always the same error " NO MATCHING DATA " could it be there is something wrong with my Plugin ? I use Zbrush4R2 on a Mac …The Plugin was included through the installation… Thanks for your Help …
I’m not aware that there are any problems on the Mac. But you could try downloading the Mac version of Transpose Master from the Download Center and installing that. Be sure to remove the previous Transpose Master version (delete the TPoseMasterData4 folder and the TransposeMaster_4_xx.ZSC file from the ZStartup/ZPlugs folder) before installing.
@marcus … just downloaded the plung and reusesd it … got the same issue " No Matching Data ":frowning:
By the Way if use the old Zbrush4 Version it works very well and aweosme without any issue ?! … Maybe I have to reinstall it or wait until the new version R2b came out ??
If you always get the error with 4R2 then I don’t know what the problem is. I’m not aware that other users are having problems with the Mac version of 4R2 and Transpose Master. It may be something to do with your set up but I can’t think why that should be the case.
Hey Marcus , I just reinstalled ZbrushR2 maybe there was something wrong inside … now everything works great fine … the only thing i get sometimes error messages about " Error encountered while importing a file " Is there any important spezification about a mesh that I don´t know … ??
hi,
a friend told me that you should add a zbrush primitive at the bottom of your subtools-list before using transpose master - since i am doing that, transpose master works perfect (which it did not before!)…
strange, but this is the world of zbrush :slight_smile:
:stuck_out_tongue:
Thanks Michael … I give it a try , by the way should i bake my 3D Layeres before I use TransposeMaster ??
that´s a good question; sometimes it works, sometimes it doesn´t
as soon as i have some time i will set up a test scene for this issue and try to analyze it, i´ll let you know
or maybe somebody else knows “the rules”?
m
