projection master
Hi!!! I have an “old” workflow, (I know, zapplink would be probably better), which is: with uv master, I make the uv map… then, with projection master, I drop the tool, and export the document in photoshop… paint in photoshop… then, import the document, and press “pick up”… ok, this workflow works perfectly in zbrush 4R4, but get in a buggy and strange results in z4R6… until to day, I had the two versions 4r4 and 4r6… for an unknown reason, 4r4 has “vanished”, and don’t open now… how to get back my workflow in 4r6? or getting back to life 4r4??? thank you for help!!!
Hello Marcel,
ZAppLink would be simpler. :slight_smile:
However, instead of your workflow you might try:
  1. After painting in Photoshop, import into the Texture palette.
  2. Select the image.
  3. Turn off Texture>Cd (Clear Depth).
  4. Press Texture>CropAndFill.
  5. Pick up from Projection Master.
HTH,
Thank you, Marcus!!! unfortunely, this path get the same issue: the tool becomes curiously impossible to move, and the texture don’t “take” the pick up… arghhh, is it impossible to get back a version, in the same computer, of Z4R4???
That’s strange. It works for me. I don’t understand how your 4R4 version can have vanished. Assuming it is still installed have you tried double-clicking the zbrush.exe file (rather than using a shortcut). If that doesn’t work then presumably the installation has become corrupted in some way. I don’t know how much 4R4 is supported but you could try submitting a ticket at support.pixologic.com
