Projection master
I just recently got a copy of Zbrush r4. I just noticed that projection master doesn’t work properly. Every time I try to do double sided projection, it just works on one side and not the other. I tried changing projection options but nothing seems to work. It still projects one-side. Maybe someone encountered the same problem, how to fix this?
That is a known issue and I believe the developers are aware of it. For a workaround, Go to ‘Tool > Display Properties’ and enable ‘Double’ before you go into Projection Master.
Much appreciate the help.
It works now )
Phew, this was driving me INSANE. Was up all night trying to figure out why it’s not working in R4. Thanks zber2!
100000000000000 thanks zber2 The problem with zbrush 4-projection master, make me ***921;NSANE
