projection master texturing problems...
I’m trying to texture head using old method that you put plane3d with texture in front of it and than pull texture into right places. But the problem is when using move brush i got black spots and texture isn’t moving and sometimes whole plane is moving
Are you using the Image Plane plugin ? If not then doing so may solve the problem.
Grate, Image plane helped… the only strange thing is that when moving map the point isn’t positioned where cursor is.
