Projection master problem
Hi, i have a problem using Projection master to colorize my model.
When i paint in front of the model, the colour goes in the back part too.
It’s not set to Double Sided, the only option active is the Colour…i simply want that the colour goes only where i paint and not behind too.
Thanks
Are you polypainting, or are you painting texture? If you’re painting texture, then odds are good that the UV’s are overlapping in places.
