Projection master problem in 4R5
Hi guys, i am using ZB version 4r5 and i have a problem. I am trying to use proj. master with Deformation, Double Sided, and Normalized options ticked on, then i put a storke with stroke type “Line” but the details don`t transfer to the backside of the object. Here is how it looks
In ZB version 4R2 this worked, but not now. Am i doing something wrong or is it ZBrush bug?
That is a known issue. As a workaround for now, turn on ‘Double’ in ‘Tool > Dispaly Properties’ before you go into Projection Master.
Thank you, that worked!!!
