projection master only project on one side?
Hi, sorry for the newbie question, but I could not find existing threads about this.
so I’m trying to follow the zclassroom tutor to make columns
http://www.pixologic.com/zclassroom/homeroom/lesson/projection-master/
started from a cube with reasonable res, drop it in PM, double side check, using simpleBrush draw a line all the way across, pick it up. unlike the video, I only have one side bumping out, nothing happened to the other sides.
is there anything I missed?
thanks for the help
Hello.
This is a recent bug. You can sort of get around it by enabling Tool: Display Properties: Double, although this might not do justice to the sides of the mesh (even with normalized on)
thank for the quick reply
it worked when “double” display enabled.
well, now I can move forward
:smiley:
