Hello
I have been using Project Master successfully today. But now Project Master does not behave as before. I have attempted restarting ZBrush, initialising ZBrush and even restarting my PC but PM does not function as before. I am pretty sure the sequence I am following is exactly the same as when it was working.
I am doing the following…
Load tool
Load up ztl file
Place active 3D object on the canvas
Press projection master
Deselect colors, materials
Select Deformation
Deselect Normalized
Press Drop Now
Using an Alpha, with texture off and DragRect Stroke i add some texture to my 3D model
Press Projection Master
With the same options as before I select Pick Up Now
The texture is lost and the model reverts back to what it was before the Projection Master Drop Now.
Anyone any ideas on what is going wrong here?
Thank you
Lin
