projection master help
to start things off, hi i just started using zbrush and it rocks so far but i cant get the projection master to pick up colors…i paint the colors on the tool and hit pick up now. after this the colors go away and the current texture stays all white… and i have the colors box checked … i have zb 3.1. thank you
Most likely, the model has no UV’s or the UV’s have been disabled (which also means no UV’s at all). Make sure that UV’s are active. The Tool>Texture>Enable UV’s button will be available if UV’s are inactive.
After making sure that UV’s are available (or enabling them if they weren’t), try pressing Tool>Texture>GUVTiles. If Projection Master works fine after that, then the problem was the UV mapping.
sweet that worked…thank you vary much
