Projection Master fails.
I’m having an issue in 3.5 r3 when I use the projection master. I always make sure the Perspective is turned off before entering Projection Master. But, whenever I pick the the tool back up and exit Projection master the perspective button is automatically turning on and causing the projections to project through my mesh at odd angles instead of shooting straight through like it should when perspective is turned off.
Has anyone else had this same issue or know of a possible workaround?
http://www.zbrushcentral.com/showthread.php?t=82322
Woot, apologies for the double post.
Thanks Spaceboy412 I had gotten busy with work and involved with an entire different set of issues then this came up again.
Markus is correct. Saving the tool with perspective turned off fixes the problem.
