projection master error
Hi all,
I’m using projection master in 3.5r3 but can only drop the model down once then I get this error…
projection mapping can not used while 3d-Displacement mode is active
I’ve never encountered it before
many thanks
same here, it is very weird, If I try after load the scene works, but if I active texture even when I uncheck the texture display doesn’t work.
Any ideas how make it work again?
