Projection Master Error
Never seen this before
I have the mesh divided into diffrent uv groups 0 to 1 space set up a poly groups with the uvs, went into paint the model and got this error the attached image, never seen this before and have used this workflow many times
amd 64 939 pin
184 pin ram 2 gigs
256 nforce g series card
windows xp home edition
When you get this error, simply restart ZBrush. That resolves it.
thanks
i also found a uv that was overlapping in the mesh ; could that have been the cause?
Not of this error, but it would have created problems with texturing and would have prevented displacement or normal map creation. Good catch!
aurick is there a reason i dont have acess to the prduction pipelines guide in the main forum sticky post???
steventaylor, you do not have permission to access this page. This could be due to one of several reasons:
  1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else’s post, access administrative features or some other privileged system?
  2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
There sure is. Somebody changed the URL on me when the most recent one was added. I’ve fixed the link. Thanks.
