Hello,
I’m having a really annoying problem…
whenever I try to make paint or bevel modifications in Projection Master and have it double sided I get weird paint problems…
The attached picture shows on the right side some gray lines I made which I wanted to go through to the other side…
And on the left side you can see the result on the other side, for some reason it didn’t only copy the gray lines but also some of its surrounding paint or something…
How can I fix that?
Thank you.
