Projection Master alpha correction?
Greetings to all,
Noob warning!
Tried searching the documentation for a solution to this, maybe someone here has run into it.
Trying to get an alpha to lay correctly across the model in Projection master. It seems that the alpha is being projected opposite the direction shown in the tool window. Would this have something to do with the axis of the model when it was imported?
Also although the document is the same size as the alpha it only projects as a square rather than rectangular, is there an option to allow this? I cannot find a solution in the alpha pallet.
TIA
