Projection and/or cage low rez questions...?
So here’s the deal. I have a very good final ztool, I exported this obj and did some retopology in another app. I also added some polys in Max.
Is there anyway to bring this into Zbrush while preserving the upper sub-d of my tool?
I’ve tried projection all and zbrush whacks out the added polys I created in Max. Is there another way to do this?
Just have your tool loaded, then import the new object, and it should ask you if you want to transfer the detail.
