I have noticed the “Zproject” brush will reset a transpose line.
This makes it impossible to use transpose to “clone” details (sculptural or texture) from the canvas to your mesh.
workflow should be:
Have two meshes, orinetate the mesh with details then drop out of edit mode (essentialy dropping it to canvas).
Select another mesh activate edit mode, then draw a transpose line from the active mesh to the one droped on the canvas.
Now when you enter the zproject brush it should read the details from whatever is under the transpose end line and transfer it to your active mesh.
The problem is the zproject brush resets the transpose line therefore there is no end line to read from the canvas…?
Any ideas how to fix this?
btw I am using windows 7
thanks for any suggestions or answers if you have encountered this problem
cheers
