ProjectAll not working.
ZBrush 3.5R2 ( vista, 3 gb )
Hi! Are there any things to keep in mind before attempting to use the ProjectAll
feature? I created a model by combining ( using insert mesh ) various skinned Zsketches. I then made a unified skin of the model at a fairly high resolution ( approx 600 ).
When I append the original mesh( 1175532 polys ) to the skinned model ( 565459 polys ) and hit ProjectAll ( i don’t change the default projectAll settings ), Zbrush goes into processing something endlessly, showing no progress bar. i can’t press esc to cancel the operation. I have to force Zbrush to shut down. Are there any settings or resolution considerations to keep in mind when using projectAll?
Not enough to go on here–theoretically you are doing the right procedure. The issue may be unique to your meshes. I suggest you put in a ticket in the support center with your meshes attached so that a developer can reproduce the lock-up you’re experiencing.
-K
