I have three subtools I’m trying to project onto 3 new retopologized subtools. The first two meshes are a success with a perfect transport of the color onto the new meshes. But now the third mesh is barely projecting anything with the exact same settings as the other two meshes(these meshes are relatively the same size). I increase the distance settings until i start getting some kind of color projection, but now the color is grabbing from places that it isn’t supposed to(the sort of result you would get with a very high distance setting). So it seems like zbrush is not seeing the second mesh until the distance is way too high, at which point the mesh is projecting things it isn’t supposed to. Any ideas how to fix this?
Just some info. The two meshes are exactly on top of each other, so I don’t think that’s the problem. PA blur is set to 16. I start seeing color projection at around 0.4 distance(.01 on the first two meshes)
