project master does’t work with my model.I tried to make a stensil(alfa)and after pressing “pick it now” the model flips
Was the stencil still turned on when you used the Pick Up feature? It should be turned off first.
I meant alfa, I did the same operations with other models and everything worked correct.you can watch my video http://www.youtube.com/watch?v=YsAF5DXgJ1c
It’s hard to tell from the movie, but I don’t think the model has flipped. I think it’s the normals. When you rotate the model slightly it looks like you’re seeing through it, inside out. That would be flipped normals. What happens if you use Tool>Display Properties>Flip?
zbrush crashes…:(((
