I’m using the latest version of Zbrush 3.5sr3 and I think I know the answer, but I’d thought I would double check.
Is there a way to project detail from one object to another in the same way as older versions of Zbrush in that you use the action line (move selected) and move select the point of projection from one object to the other and then select the draw tool and draw away. Then the detail from one object transfers to the other.
I ask because this method is so handy in many ways and I can’t seem to make it happen with this newest version. I prefer this method over projection master.
Will this be fixed in Version 4 if it doesn’t work this way now?
Here is a link to a video I did on the way I need this to work.
](javascript:zb_insimg(‘206719’,‘example.jpg’,1,0))
